Micamold Capacitor Value and Type ???
Thanks for your reply. If the bottom dots are the cap value, I think it should be 30 X 100 = 3000pf.
First digit (orange) =3, second digit (black) = 0, and multiplier (red) = 2 or 100. At 3000 pf, it is unclear to me if this is a encapsulated paper cap or a mica.
Any thoughts will be appreciated as the schematic does not detail the value or type for this cap.
Thanks
Micamold Capacitor Value and Type ??? - by TFB - 02-27-2010, 04:24 PM
Re: Micamold Capacitor Value and Type ??? - by TFB - 02-27-2010, 10:40 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
