Model 66 - help post recap
450v is pretty much standard fair these days which is fine.
The Jensen spkr isn't original to the set. Is it a pm or electrodynamic spkr?
If it's a pm job you'll need more filtering in the p/s to remove the hum.
Inductance is a much better filter than resistance.
Model 66 - help post recap - by gcerio - 08-29-2017, 05:59 PM
RE: Model 66 - help post recap - by Radioroslyn - 08-29-2017, 06:41 PM
RE: Model 66 - help post recap - by gcerio - 08-29-2017, 09:19 PM
RE: Model 66 - help post recap - by Radioroslyn - 08-29-2017, 10:31 PM
The speaker table error?
Philco 70 antenna lead
