Philco Model 71 Code 221
I mean all the caps. My model is code 221 so I can see the extra cap there for the two speaker circuit.
Philco Model 71 Code 221 - by JohnJarratt - 07-24-2017, 08:08 AM
RE: Philco Model 71 Code 221 - by morzh - 07-24-2017, 08:49 AM
RE: Philco Model 71 Code 221 - by Radioroslyn - 07-24-2017, 01:17 PM
RE: Philco Model 71 Code 221 - by klondike98 - 07-24-2017, 01:22 PM
RE: Philco Model 71 Code 221 - by JohnJarratt - 07-24-2017, 03:58 PM
RE: Philco Model 71 Code 221 - by JohnJarratt - 08-30-2017, 02:05 PM
RE: Philco Model 71 Code 221 - by morzh - 08-30-2017, 02:12 PM
RE: Philco Model 71 Code 221 - by JohnJarratt - 08-30-2017, 02:53 PM
RE: Philco Model 71 Code 221 - by grandntl - 08-30-2017, 02:58 PM
RE: Philco Model 71 Code 221 - by JohnJarratt - 08-30-2017, 03:01 PM
RE: Philco Model 71 Code 221 - by grandntl - 08-30-2017, 03:08 PM
The speaker table error?
Philco 70 antenna lead
