philco 490 speaker
Perhaps your spkr came from a baby grand (table top) set rather than a console. The important issues are the output transformer, does it have 4 or 5 wires ? If it has 5 wires it would be for a push/pull output stage which wouldn't give you a good impedance match for your single 47. You want to see 4 wires.
And the other is is the field coil good? If not then you will need to rewind it or find a spkr w/a good one.
Lead length isn't much of a problem, at 80+yrs old it would hurt to replace them anyway.
philco 490 speaker - by mg34.42 - 09-02-2017, 02:14 AM
RE: philco 490 speaker - by Radioroslyn - 09-02-2017, 09:24 PM
RE: philco 490 speaker - by mg34.42 - 09-02-2017, 11:18 PM
RE: philco 490 speaker - by Radioroslyn - 09-03-2017, 11:01 AM
RE: philco 490 speaker - by mg34.42 - 09-04-2017, 12:36 AM
RE: philco 490 speaker - by Radioroslyn - 09-04-2017, 03:25 PM
The speaker table error?
Philco 70 antenna lead
