Solder... where?
Thanks guys! I should have thought of Amazon, Mouser, and Fry's. Any other sources are also welcomed.
Solder... where? - by Scott D - 09-03-2017, 07:23 PM
RE: Solder... where? - by morzh - 09-03-2017, 07:57 PM
RE: Solder... where? - by Nathan Slingerland - 09-03-2017, 07:58 PM
RE: Solder... where? - by dacsman - 09-03-2017, 08:47 PM
RE: Solder... where? - by Scott D - 09-04-2017, 12:57 AM
RE: Solder... where? - by WallaceRoger - 09-05-2017, 09:50 AM
RE: Solder... where? - by robsradioactive - 09-14-2017, 07:12 PM
The speaker table error?
Philco 70 antenna lead
