116X plummeting B voltage
Thanks. I really appreciate this information. Through no effort on my part, the B voltage has resumed normal values...so the problem may actually an intermittent one. I will follow through. Marc.
116X plummeting B voltage - by Guest - 02-17-2010, 06:15 PM
Re: 116X plummeting B voltage - by 7estatdef - 02-27-2010, 07:28 PM
Re: 116X plummeting B voltage - by Guest - 03-01-2010, 07:34 PM
Re: 116X plummeting B voltage - by 7estatdef - 03-01-2010, 09:11 PM
Re: 116X plummeting B voltage - by Ron Ramirez - 03-02-2010, 09:44 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
