116X schematic reliability
Sounds OK I don't think it's a problem. Would double check by trying to align the transformer.
116X schematic reliability - by Guest - 03-01-2010, 07:47 PM
Re: 116X schematic reliability - by 7estatdef - 03-01-2010, 08:57 PM
Re: 116X schematic reliability - by Ron Ramirez - 03-02-2010, 09:46 AM
Re: 116X schematic reliability - by Guest - 03-02-2010, 01:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
