  • 1 Vote(s) - 2 Average
Philco 37-670B
Ron, you might also check resistors 78 and 79. These form a voltage divider and filtering network (along with C37A) for the osc B+ supply. If they have changed in value it could reduce the voltage available at turn on, delaying start of the osc.
Philco 37-670B - by Ron Ramirez - 09-27-2015, 05:40 PM
RE: Philco 37-670B - by sam - 09-27-2015, 06:16 PM
RE: Philco 37-670B - by Ron Ramirez - 10-08-2015, 03:24 PM
RE: Philco 37-670B - by Kenneth F. Besso Jr. - 10-08-2015, 08:30 PM
RE: Philco 37-670B - by KCMike - 10-08-2015, 08:37 PM
RE: Philco 37-670B - by Ron Ramirez - 10-09-2015, 10:06 PM
RE: Philco 37-670B - by klondike98 - 10-09-2015, 11:56 PM
RE: Philco 37-670B - by Nathan Slingerland - 10-10-2015, 01:07 AM
RE: Philco 37-670B - by TA Forbes - 10-10-2015, 08:21 AM
RE: Philco 37-670B - by sam - 10-10-2015, 12:21 PM
RE: Philco 37-670B - by TA Forbes - 10-10-2015, 07:15 PM
RE: Philco 37-670B - by Ron Ramirez - 10-10-2015, 08:34 PM
RE: Philco 37-670B - by morzh - 10-10-2015, 08:44 PM
RE: Philco 37-670B - by Radioroslyn - 10-10-2015, 08:54 PM
RE: Philco 37-670B - by Ron Ramirez - 10-10-2015, 09:08 PM
RE: Philco 37-670B - by Ron Ramirez - 09-03-2017, 10:39 PM
RE: Philco 37-670B - by morzh - 09-03-2017, 11:44 PM
RE: Philco 37-670B - by Ron Ramirez - 09-04-2017, 08:09 AM
RE: Philco 37-670B - by morzh - 09-04-2017, 08:35 AM
RE: Philco 37-670B - by Ron Ramirez - 09-04-2017, 09:21 AM
RE: Philco 37-670B - by Mondial - 09-04-2017, 09:56 AM
RE: Philco 37-670B - by Ron Ramirez - 09-04-2017, 03:48 PM
RE: Philco 37-670B - by Mondial - 09-04-2017, 08:32 PM
RE: Philco 37-670B - by Ron Ramirez - 09-04-2017, 09:48 PM
RE: Philco 37-670B - by Ron Ramirez - 07-02-2018, 09:55 PM
RE: Philco 37-670B - by Brad Winder - 07-02-2018, 10:56 PM
RE: Philco 37-670B - by morzh - 07-02-2018, 10:59 PM
RE: Philco 37-670B - by Kenradio - 07-03-2018, 12:56 AM
RE: Philco 37-670B - by Ron Ramirez - 07-03-2018, 09:53 PM
RE: Philco 37-670B - by Ron Ramirez - 07-04-2018, 10:06 PM
RE: Philco 37-670B - by Ron Ramirez - 07-04-2018, 10:10 PM
RE: Philco 37-670B - by Ron Ramirez - 07-04-2018, 10:16 PM
RE: Philco 37-670B - by Ron Ramirez - 07-04-2018, 10:19 PM
RE: Philco 37-670B - by Ron Ramirez - 07-04-2018, 10:23 PM
RE: Philco 37-670B - by NostalgiaRadioTime - 07-04-2018, 11:22 PM
RE: Philco 37-670B - by mikethedruid - 07-05-2018, 12:25 AM
RE: Philco 37-670B - by NostalgiaRadioTime - 07-05-2018, 12:51 AM
RE: Philco 37-670B - by Ron Ramirez - 07-05-2018, 09:53 AM
RE: Philco 37-670B - by WyTex - 07-05-2018, 10:17 AM
RE: Philco 37-670B - by Ron Ramirez - 07-05-2018, 10:39 AM
RE: Philco 37-670B - by GarySP - 07-05-2018, 11:03 AM
RE: Philco 37-670B - by Nathan Slingerland - 07-05-2018, 11:11 AM
RE: Philco 37-670B - by Ron Ramirez - 07-05-2018, 12:50 PM
RE: Philco 37-670B - by Nathan Slingerland - 07-05-2018, 01:00 PM
RE: Philco 37-670B - by Arran - 07-11-2018, 06:04 PM
RE: Philco 37-670B - by morzh - 07-11-2018, 06:36 PM
RE: Philco 37-670B - by Ron Ramirez - 07-11-2018, 07:13 PM
Users browsing this thread: 21 Guest(s)
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4956 online users. [Complete List]
» 2 Member(s) | 4954 Guest(s)
