38-15 Chairside Antenna
Thanks guys!
Only the floor is concrete and steel. The main floor is frame. So with your info, I think there might really be an issue with it.
I remember testing the tubes and replacing a few, but now I don't remember which ones, or if I just did an emissions test or a Gm test. (Not that any tester is 100% reliable.)
I think I'll do some more tube testing and switching out. I'll post back with what happens after that.
Rob
38-15 Chairside Antenna - by robsradioactive - 09-05-2017, 08:56 AM
RE: 38-15 Chairside Antenna - by Radioroslyn - 09-05-2017, 11:51 AM
RE: 38-15 Chairside Antenna - by morzh - 09-05-2017, 01:53 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-05-2017, 06:53 PM
RE: 38-15 Chairside Antenna - by morzh - 09-05-2017, 11:09 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-06-2017, 08:56 PM
RE: 38-15 Chairside Antenna - by morzh - 09-06-2017, 09:20 PM
RE: 38-15 Chairside Antenna - by Chris h - 09-07-2017, 11:02 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-09-2017, 03:45 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-11-2017, 11:13 PM
The speaker table error?
Philco 70 antenna lead
