38-15 Chairside Antenna
Hi Rob,
If swapping tubes doesn't make a difference you might check out this thread. Some of us have had very good luck with these antennas:
http://philcoradio.com/phorum/showthread.php?tid=16904
38-15 Chairside Antenna - by robsradioactive - 09-05-2017, 08:56 AM
RE: 38-15 Chairside Antenna - by Radioroslyn - 09-05-2017, 11:51 AM
RE: 38-15 Chairside Antenna - by morzh - 09-05-2017, 01:53 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-05-2017, 06:53 PM
RE: 38-15 Chairside Antenna - by NostalgiaRadioTime - 09-05-2017, 09:51 PM
RE: 38-15 Chairside Antenna - by morzh - 09-05-2017, 11:09 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-06-2017, 08:56 PM
RE: 38-15 Chairside Antenna - by morzh - 09-06-2017, 09:20 PM
RE: 38-15 Chairside Antenna - by Chris h - 09-07-2017, 11:02 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-09-2017, 03:45 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-11-2017, 11:13 PM
The speaker table error?
Philco 70 antenna lead
