Kirk's Sparton 65
#32
Stoopid NF capacitors!!!!!
Kirk's Sparton 65 - by morzh - 08-29-2017, 08:26 AM
RE: Kirk's Sparton 65 - by OldRestorer - 08-29-2017, 10:15 AM
RE: Kirk's Sparton 65 - by Eliot Ness - 08-29-2017, 10:43 AM
RE: Kirk's Sparton 65 - by Radioroslyn - 08-29-2017, 11:31 AM
RE: Kirk's Sparton 65 - by morzh - 08-29-2017, 01:15 PM
RE: Kirk's Sparton 65 - by morzh - 08-29-2017, 08:25 PM
RE: Kirk's Sparton 65 - by OldRestorer - 08-29-2017, 09:08 PM
RE: Kirk's Sparton 65 - by morzh - 08-29-2017, 09:35 PM
RE: Kirk's Sparton 65 - by Kenneth F. Besso Jr. - 08-30-2017, 07:16 PM
RE: Kirk's Sparton 65 - by OldRestorer - 08-30-2017, 07:16 PM
RE: Kirk's Sparton 65 - by Arran - 08-30-2017, 07:28 PM
RE: Kirk's Sparton 65 - by morzh - 08-30-2017, 08:54 PM
RE: Kirk's Sparton 65 - by OldRestorer - 08-31-2017, 07:08 AM
RE: Kirk's Sparton 65 - by morzh - 08-31-2017, 08:33 AM
RE: Kirk's Sparton 65 - by sam - 08-31-2017, 11:17 AM
RE: Kirk's Sparton 65 - by morzh - 08-31-2017, 11:38 AM
RE: Kirk's Sparton 65 - by morzh - 08-31-2017, 09:09 PM
RE: Kirk's Sparton 65 - by OldRestorer - 08-31-2017, 09:26 PM
RE: Kirk's Sparton 65 - by morzh - 08-31-2017, 09:46 PM
RE: Kirk's Sparton 65 - by sam - 08-31-2017, 11:13 PM
RE: Kirk's Sparton 65 - by OldRestorer - 08-31-2017, 11:23 PM
RE: Kirk's Sparton 65 - by morzh - 09-01-2017, 08:40 AM
RE: Kirk's Sparton 65 - by OldRestorer - 09-01-2017, 10:43 AM
RE: Kirk's Sparton 65 - by morzh - 09-01-2017, 11:08 AM
RE: Kirk's Sparton 65 - by OldRestorer - 09-01-2017, 01:47 PM
RE: Kirk's Sparton 65 - by morzh - 09-01-2017, 01:56 PM
RE: Kirk's Sparton 65 - by Arran - 09-02-2017, 12:09 AM
RE: Kirk's Sparton 65 - by morzh - 09-02-2017, 08:45 AM
RE: Kirk's Sparton 65 - by Arran - 09-03-2017, 03:27 AM
RE: Kirk's Sparton 65 - by morzh - 09-05-2017, 08:30 PM
RE: Kirk's Sparton 65 - by Radioroslyn - 09-05-2017, 11:29 PM
RE: Kirk's Sparton 65 - by morzh - 09-06-2017, 07:34 PM
RE: Kirk's Sparton 65 - by sam - 09-06-2017, 08:06 PM
RE: Kirk's Sparton 65 - by morzh - 09-06-2017, 08:12 PM
RE: Kirk's Sparton 65 - by Arran - 09-07-2017, 01:17 AM
RE: Kirk's Sparton 65 - by morzh - 09-07-2017, 08:13 AM
RE: Kirk's Sparton 65 - by OldRestorer - 09-07-2017, 12:58 PM
RE: Kirk's Sparton 65 - by morzh - 09-07-2017, 01:35 PM
RE: Kirk's Sparton 65 - by OldRestorer - 09-07-2017, 03:54 PM
RE: Kirk's Sparton 65 - by morzh - 09-07-2017, 04:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
