AK model 42 antenna transformer
Your Falcon looks in very good shape.  Hope you are able to drive it again soon.  Do you plan on doing a full restoration or just doing the engine?  I suppose you know this but the 1964-1966 Mustangs were based on the Falcon platform and even have the same instrument cluster.
I moved out to Clinton from Long Island in 1992 so Kobers was probably gone before I had a chance to use them.  I see you are into early TV's as well as radios.  I wouldn't mind restoring a few TV's but they take up too much space.  I have three pre-war consoles and my wife won't let me get any more.  I also noticed you have done a number of home built projects, are you an engineer or technician?
AK model 42 antenna transformer - by Steve D - 09-05-2017, 12:01 PM
RE: AK model 42 antenna transformer - by Steve D - 09-06-2017, 09:02 AM
RE: AK model 42 antenna transformer - by Steve D - 09-07-2017, 03:52 PM
RE: AK model 42 antenna transformer - by Steve D - 09-12-2017, 11:12 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
