To re-wire or not to re-wire....
If there is exposed chassis, I change to a polarized cord and run the hot wire to the switch and then back to the rectifier tube. I run this loop side by side and twist the wires together to minimize magnetic radiation. I try to run them around the corners of the chassis away from any audio tubes. I have never had a hum issue this way. Any line bypass caps get Y2 safety caps.
Rob
To re-wire or not to re-wire.... - by Greenhorn - 09-08-2017, 01:53 PM
RE: To re-wire or not to re-wire.... - by morzh - 09-08-2017, 02:18 PM
RE: To re-wire or not to re-wire.... - by morzh - 09-08-2017, 07:39 PM
RE: To re-wire or not to re-wire.... - by robsradioactive - 09-08-2017, 09:52 PM
RE: To re-wire or not to re-wire.... - by Arran - 09-10-2017, 09:38 PM
The speaker table error?
Philco 70 antenna lead
