38-15 Chairside Antenna
I agree. An outdoor long-wire is hard to beat. But mine comes in through a jack in another room and attached to an S-20R. Also, last week we had some tree guys out to cut back some branches and they knocked it down with their "cherry picker"...so that's a ladder job before winter.
I am going to try a small tuned loop, just for kicks. I don't used the chairside for SW listening and pretty much always just listen to 640 AM around here when I use it at all. I started building a square loop yesterday. I'll post here how it works--if it works!   Icon_crazy
Rob
38-15 Chairside Antenna - by robsradioactive - 09-05-2017, 08:56 AM
RE: 38-15 Chairside Antenna - by Radioroslyn - 09-05-2017, 11:51 AM
RE: 38-15 Chairside Antenna - by morzh - 09-05-2017, 01:53 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-05-2017, 06:53 PM
RE: 38-15 Chairside Antenna - by morzh - 09-05-2017, 11:09 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-06-2017, 08:56 PM
RE: 38-15 Chairside Antenna - by morzh - 09-06-2017, 09:20 PM
RE: 38-15 Chairside Antenna - by Chris h - 09-07-2017, 11:02 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-09-2017, 03:45 PM
RE: 38-15 Chairside Antenna - by robsradioactive - 09-11-2017, 11:13 PM
The speaker table error?
Philco 70 antenna lead
