Philco 41-608
Welcome to the Phorum!
Icon_wave
Yes there is a lot of info on this site and it can be very helpful but the first thing to let us know is how familiar are you with electronics, voltage, current, measurements etc. If all of that sounds new to you then you need to do some reading and learning before getting into the restoration. Lots of threads in the Tech section but a very good very first read can be found on Phil Nelson's site.
Philco 41-608 - by CondemnedRadios - 09-09-2017, 12:41 PM
RE: Philco 41-608 - by Nathan Slingerland - 09-09-2017, 01:42 PM
RE: Philco 41-608 - by WallaceRoger - 09-09-2017, 02:31 PM
RE: Philco 41-608 - by Radioroslyn - 09-09-2017, 04:43 PM
RE: Philco 41-608 - by klondike98 - 09-09-2017, 11:08 PM
RE: Philco 41-608 - by morzh - 09-10-2017, 08:59 AM
RE: Philco 41-608 - by CondemnedRadios - 09-17-2017, 04:40 PM
RE: Philco 41-608 - by morzh - 09-17-2017, 05:22 PM
RE: Philco 41-608 - by CondemnedRadios - 09-17-2017, 05:57 PM
RE: Philco 41-608 - by Radioroslyn - 09-17-2017, 06:07 PM
RE: Philco 41-608 - by sam - 09-17-2017, 06:59 PM
The speaker table error?
Philco 70 antenna lead
