Model 70
Hi Gary
Assuming you're working on an early 70 (without AVC), here's what I would check:
  • Antenna coil (2) and RF coil (6);
    ALL wiring from tuning condenser to the various points under the chassis;
    tightness of the screws on the sides of the tuning condenser;
    the RF amp tube, Type 24.[/list:u]
    I think it's probably a combination of bad antenna coil (2) and/or RF coil (6) and wiring/screw tightness issue on the tuning condenser.
    The second Type 24 tube from the front is the mixer tube, so your problem has to be ahead of that. The wiring/screw tightness on the tuning condenser can cause lots of intermittents.
    Hope this helps. Happy troubleshooting! Icon_smile
    (edit) Well, Chuck and I answered at almost the same time, so now you have two votes pointing to those coils. Take a look at them right away. Good luck.
Model 70 - by n9vu - 01-22-2006, 11:56 PM
[No subject] - by Chuck Schwark - 01-23-2006, 12:37 AM
[No subject] - by Ron Ramirez - 01-23-2006, 12:44 AM
[No subject] - by n9vu - 01-23-2006, 07:02 AM
[No subject] - by n9vu - 01-27-2006, 12:06 AM
[No subject] - by Ron Ramirez - 01-27-2006, 12:59 AM
[No subject] - by n9vu - 02-05-2006, 10:42 PM
There are currently 9288 online users. [Complete List]
» 2 Member(s) | 9286 Guest(s)
