Low Volume & distortion
Ron; Thanks for the quick reply. Yes, all of the capcitors have been replaced by me. the tubes are all good. Should I suspect one ofthe mica or silver mica capacitors? If so, what circuit should I look at first and how close do the replacement values of the micas have to be to the values shown on the schematic? Thanks for your help.
Low Volume & distortion - by radionut - 03-02-2010, 12:31 PM
Re: Low Volume & distortion - by Ron Ramirez - 03-02-2010, 12:58 PM
Re: Low Volume & distortion - by radionut - 03-03-2010, 08:15 PM
Re: Low Volume & distortion - by rghines1 - 03-03-2010, 09:03 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
