Fuse in Philco 610 Tombstone
Hi Bob,
You can use a fuse w/pigtails and just solder it in between the block and transformer primary. I've seen some 3AG style fuses w/ wires attached. A bit of shrink tubing and your good.
Have seen some that use automotive inline holders but I think it looks cheesey. Don't know if the insulation is up to the task either.
Fuse in Philco 610 Tombstone - by bikenepa - 09-14-2017, 10:06 AM
RE: Fuse in Philco 610 Tombstone - by Radioroslyn - 09-14-2017, 11:41 AM
RE: Fuse in Philco 610 Tombstone - by bikenepa - 09-14-2017, 11:48 AM
RE: Fuse in Philco 610 Tombstone - by Radioroslyn - 09-14-2017, 12:01 PM
RE: Fuse in Philco 610 Tombstone - by Steve D - 09-15-2017, 05:03 PM
RE: Fuse in Philco 610 Tombstone - by bikenepa - 09-18-2017, 03:14 PM
The speaker table error?
Philco 70 antenna lead
