Recap 48-482
Sean-
Thanks for the reply. The recapping looks like a pretty daunting task, especially with those multi-section capacitors. Even figuring out what caps I need... Anyway, I am planning on trying your trick with the tubes and sockets first. It is really frustrating, though, that the thing worked quite nicely for several days.
Anyway, thanks again!
Tim
P.S. It looks like we are practically neighbors. I live just down the road in Rolla. :-)
Recap 48-482 - by Guest - 03-03-2010, 04:46 PM
Re: Recap 48-482 - by Sean - 03-03-2010, 05:12 PM
Re: Recap 48-482 - by Guest - 03-04-2010, 07:39 PM
Re: Recap 48-482 - by Sean - 03-04-2010, 09:30 PM
Re: Recap 48-482 - by Guest - 03-04-2010, 10:06 PM
Re: Recap 48-482 - by Sean - 03-05-2010, 10:37 AM
Re: Recap 48-482 - by Guest - 03-05-2010, 09:43 PM
Re: Recap 48-482 - by gary rabbitt - 03-06-2010, 02:46 AM
Re: Recap 48-482 - by Joe Rossi - 03-06-2010, 11:23 AM
Re: Recap 48-482 - by Ron Ramirez - 03-06-2010, 04:33 PM
Re: Recap 48-482 - by Guest - 03-06-2010, 11:15 PM
Re: Recap 48-482 - by Joe Rossi - 03-07-2010, 10:15 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
