Fuse in Philco 610 Tombstone
I prefer chassis a mounted fuse holder for which I can usually find a spot to affix near the AC line cord entry.  Here is one example (zoom in on lower right corner):
http://galleries.mine.nu/steves/gallery/...520?full=1
Steve D
Fuse in Philco 610 Tombstone - by bikenepa - 09-14-2017, 10:06 AM
RE: Fuse in Philco 610 Tombstone - by Radioroslyn - 09-14-2017, 11:41 AM
RE: Fuse in Philco 610 Tombstone - by bikenepa - 09-14-2017, 11:48 AM
RE: Fuse in Philco 610 Tombstone - by Radioroslyn - 09-14-2017, 12:01 PM
RE: Fuse in Philco 610 Tombstone - by Steve D - 09-15-2017, 05:03 PM
RE: Fuse in Philco 610 Tombstone - by bikenepa - 09-18-2017, 03:14 PM
The speaker table error?
Philco 70 antenna lead
