Philco 118 - Power Transformer Shorted?
Unless it is a short in the wiring to the transformer or between its secondary and the rectifier, I would say yes.
Yes it does matter what wattage you are using for a lamp. I assume you know what to use for the lamp.
Rob
RE: Philco 118 - Power Transformer Shorted? - by robsradioactive - 09-15-2017, 09:41 PM
The speaker table error?
Philco 70 antenna lead
