Ext. Antenna Hookup
I'm working on the same radio at the moment and recapped the whole thing. I'm still working through resistors. I finally got sounds out of it, but they're pretty staticky and weak reception. Would not grounding the black to ground make any difference in receiving stations?
Thanks
Bernie
Ext. Antenna Hookup - by jmac3ky - 06-08-2017, 03:34 PM
RE: Ext. Antenna Hookup - by Ron Ramirez - 06-08-2017, 06:28 PM
RE: Ext. Antenna Hookup - by jmac3ky - 06-08-2017, 08:32 PM
RE: Ext. Antenna Hookup - by beanderson - 09-15-2017, 11:02 PM
RE: Ext. Antenna Hookup - by robsradioactive - 09-18-2017, 06:36 PM
The speaker table error?
Philco 70 antenna lead
