Northern Electric 921 cabinet finished
Outstanding!
Cold Calgary winter nite, warm dial light, hot drink......
Enjoy it.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
