41-280 alignment
Hi Dave and welcome,
As a troubleshooting measure I'd loose couple a frequency counter to the oscillator.  Frequency received or dial frequency = oscillator frequency - 455kc.
It's important that the osc is running above the incoming signal rather than below.
Have you check the XXL/7A4 osc tube, it may be weak causing the osc to die out at hf.
41-280 alignment - by dmaugus - 09-18-2017, 11:22 PM
RE: 41-280 alignment - by klondike98 - 09-19-2017, 10:59 AM
RE: 41-280 alignment - by Radioroslyn - 09-19-2017, 12:59 PM
RE: 41-280 alignment - by Raleigh - 10-03-2017, 05:24 PM
RE: 41-280 alignment - by Radioroslyn - 10-03-2017, 06:06 PM
The speaker table error?
Philco 70 antenna lead
