Novice questions about restoring 39-7
Hi And Welcome,
The part in question is called the output transformer. It has four wires. The important part is that two wires on the back side ( these are called the primary) that go to the 41 tube socket show some resistance (around 200-600 ohms roughly). If they show a much higher resistance or open it's kaput. Would be helpful to see a side view of the spkr too.
RE: Novice questions about restoring 39-7 - by Radioroslyn - 09-19-2017, 01:22 PM
The speaker table error?
Philco 70 antenna lead
