Novice questions about restoring 39-7
I've seen many small output transformers that looked like this, that worked just fine; all they needed is a good blow from a canned air duster.
Re-coning - yes, kinda painfully obvious.
RE: Novice questions about restoring 39-7 - by morzh - 09-19-2017, 03:31 PM
The speaker table error?
Philco 70 antenna lead
