41-290 Component Values
I attempting to restore a 41-290 (code 121) and have identified a couple of discrepancies between the as built (as-manufactured) unit and the available schematics. Specifically, item #41 (resistor) is specified as 33K ohms whereas the resistor installed is 100K ohms and item #45 (capacitor) is specified to be .01 mf where as the installed item is .003 mf. As far as I can tell from visual inspection the 100K ohm resistor and the .003 mf cap appear to be as factory built. The following illustration details the discrepancies.
Any thoughts from the members/experts will be appreciated.
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
41-290 Component Values - by TFB - 03-08-2010, 05:25 PM
Re: 41-290 Component Values - by Ron Ramirez - 03-08-2010, 07:50 PM
Re: 41-290 Component Values - by TFB - 03-08-2010, 10:10 PM
Re: 41-290 Component Values - by dberman51 - 03-09-2010, 08:27 PM
Re: 41-290 Component Values - by Ron Ramirez - 03-09-2010, 08:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
