1941 Philco push button on/off switches
Ron / rickd
I followed your suggested Radio Shack switch replacement/restoration for a 41-290. It appears to have work great. Thanks for posting and maintaining these information.
[No subject] - by Ron Ramirez - 11-22-2005, 12:50 AM
[No subject] - by Bill Hutchinson - 11-22-2005, 08:05 PM
Success! - by Raleigh - 06-13-2007, 06:23 PM
[No subject] - by rickd - 06-16-2008, 03:22 PM
[No subject] - by Chuck Schwark - 06-16-2008, 04:08 PM
[No subject] - by rickd - 06-16-2008, 05:07 PM
Re: 1941 Philco push button on/off switches - by TFB - 03-08-2010, 05:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
