Coranado 907
Well I even spelled Coronado wrong, but anyway, maybe something like this?
https://www.surplussales.com/Inductors/I...jRF-1.html
The chassis is still in cabinet, looks like it has bounced off the bolts.
You can see how it looks, kinda bounced off but not  sure if she works, need to go see my friend with Variac, and bring it up slow, should have my own.
https://www.flickr.com/photos/92577012@N...5873416030
Pablo
Coranado 907 - by Paul Philco322 - 09-28-2017, 08:46 PM
RE: Coranado 907 - by Radioroslyn - 09-28-2017, 10:54 PM
RE: Coranado 907 - by Paul Philco322 - 09-29-2017, 08:30 PM
RE: Coranado 907 - by Radioroslyn - 09-30-2017, 12:32 AM
RE: Coranado 907 - by Paul Philco322 - 09-30-2017, 07:43 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6964 online users. [Complete List]
» 1 Member(s) | 6963 Guest(s)
