GE Model 200
I believe,, they are clips-- that flip open---out-----BUT could be __WRONG,,,,and they JUST ,,lift a little to get glass out??????//// they also look like fansworth clips,,,with a little wedge in them ,,to hold that main part tight,,and down ,or against the glass,,,,,Can't really tell from this point of vision,,,----hope that may HELP-----CHEERS
GE Model 200 - by vecher - 09-30-2017, 06:14 PM
RE: GE Model 200 - by Kenneth F. Besso Jr. - 09-30-2017, 10:54 PM
RE: GE Model 200 - by vecher - 10-01-2017, 10:16 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
