Service bulliten for 37-9 question
There are not many lines to the service bulletin, but one is a bit confusing.
For electrolytic cap #70 which is a multiple it says to replace the 10/20 mF with 8/10 mF. Not too bad but it says that the new 10mF should replace 70A which is already the 10mF.
Am I reading this correctly that the 20mF should be replaced with an 8mF and the 10mf should be left as a 10mF?
Thanks and regards,
Kurt
Service bulliten for 37-9 question - by wu8v - 03-09-2010, 08:11 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4372 online users. [Complete List]
» 1 Member(s) | 4371 Guest(s)
