37-630....middle of the road set?
Problem is, the seller might not, her likely being a non-tech-savvy person, have any good answers for you.
(she would know if the radio was in a wet basement or flooded, but then this should be pretty clear from photos).
When hauling the 37-116 keep in mind: the chassis is held by ONE SINGLE 4-40 or 6- 32 screw. Yes, you heard me right.
So, take the chassis out of it. And as long as you are at it, the other radio also might use the chassis out while being transported.
37-630....middle of the road set? - by dal61 - 10-01-2017, 01:54 PM
RE: 37-630....middle of the road set? - by dal61 - 10-01-2017, 04:38 PM
RE: 37-630....middle of the road set? - by dal61 - 10-01-2017, 08:59 PM
RE: 37-630....middle of the road set? - by dal61 - 10-01-2017, 11:30 PM
RE: 37-630....middle of the road set? - by dal61 - 10-02-2017, 07:24 AM
RE: 37-630....middle of the road set? - by dal61 - 10-02-2017, 10:43 PM
RE: 37-630....middle of the road set? - by morzh - 10-02-2017, 10:54 PM
RE: 37-630....middle of the road set? - by dal61 - 10-02-2017, 11:29 PM
RE: 37-630....middle of the road set? - by SteveG - 10-02-2017, 11:40 PM
RE: 37-630....middle of the road set? - by dal61 - 10-03-2017, 07:34 AM
RE: 37-630....middle of the road set? - by dal61 - 10-03-2017, 12:32 PM
RE: 37-630....middle of the road set? - by morzh - 10-03-2017, 01:17 PM
RE: 37-630....middle of the road set? - by dal61 - 10-03-2017, 05:03 PM
RE: 37-630....middle of the road set? - by morzh - 10-03-2017, 05:08 PM
RE: 37-630....middle of the road set? - by dal61 - 10-03-2017, 08:20 PM
RE: 37-630....middle of the road set? - by Arran - 10-03-2017, 10:25 PM
RE: 37-630....middle of the road set? - by dal61 - 10-05-2017, 01:15 PM
RE: 37-630....middle of the road set? - by SteveG - 10-05-2017, 03:32 PM
RE: 37-630....middle of the road set? - by dal61 - 10-08-2017, 03:25 PM
RE: 37-630....middle of the road set? - by dal61 - 10-08-2017, 07:24 PM
RE: 37-630....middle of the road set? - by dal61 - 10-09-2017, 10:18 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4366 online users. [Complete List]
» 1 Member(s) | 4365 Guest(s)
