Crosley 106CP Modulation Hum
I was pretty sure I'd missed something in my restoration until I brought the chassis and speaker back home. I had tested it originally with a random wire test antenna, so I figured maybe there was enough hash and static that I didn't notice the modulation hum. But when I dummied up a loop similar to the Crosley original and it was quiet with no hum, I figured it had to be something at the site.
I'll have him turn off lights and so forth if he has fluorescent lights. Thanks for the tip about chargers. I was wondering if there could be anything wrong with the way the outlet was wired that would make this happen, like if it had a bad ground connection or something. Any thoughts?
But here is one more question. If it were interference at the site, I can't figure out why it would show up as modulation hum instead of humming across the band and not just on as station.
John Honeycutt
Crosley 106CP Modulation Hum - by Raleigh - 10-02-2017, 01:56 PM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-02-2017, 08:00 PM
RE: Crosley 106CP Modulation Hum - by Radioroslyn - 10-03-2017, 04:24 AM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-03-2017, 05:35 PM
RE: Crosley 106CP Modulation Hum - by Arran - 10-03-2017, 11:07 PM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-04-2017, 12:12 PM
RE: Crosley 106CP Modulation Hum - by Radioroslyn - 10-04-2017, 01:02 PM
RE: Crosley 106CP Modulation Hum - by Mondial - 10-05-2017, 05:52 AM
RE: Crosley 106CP Modulation Hum - by Arran - 10-06-2017, 12:10 AM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-07-2017, 09:08 AM
RE: Crosley 106CP Modulation Hum - by Radioroslyn - 10-07-2017, 02:50 PM
RE: Crosley 106CP Modulation Hum - by Arran - 10-09-2017, 02:26 AM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-11-2017, 04:44 PM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-19-2017, 05:29 PM
RE: Crosley 106CP Modulation Hum - by Ron Ramirez - 10-20-2017, 10:55 AM
RE: Crosley 106CP Modulation Hum - by morzh - 10-20-2017, 11:44 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
