More Model 60 Coil Questions
Hi Scottie
Welcome!
Using 34G wire shouldn't be a problem at all. The key is to make sure you have enough turns if you don't the osc won't oscillate across the whole band. If memory serves me it won't oscillate at the low end of the band. The resistance the the IF coils shouldn't be a problem either as long as they peak at the IF frequency. With them not tuned on frequency it is very likely that it will break into oscillation.
Good luck
More Model 60 Coil Questions - by Guest - 03-10-2010, 06:47 PM
Re: More Model 60 Coil Questions - by 7estatdef - 03-11-2010, 07:13 PM
Re: More Model 60 Coil Questions - by Guest - 03-11-2010, 07:34 PM
Re: More Model 60 Coil Questions - by 7estatdef - 03-12-2010, 07:07 PM
Re: More Model 60 Coil Questions - by exray - 03-12-2010, 10:04 PM
Re: More Model 60 Coil Questions - by 7estatdef - 03-13-2010, 07:50 PM
Status update and background - by Guest - 03-14-2010, 12:40 PM
Re: More Model 60 Coil Questions - by exray - 03-14-2010, 10:06 PM
Re: More Model 60 Coil Questions - by Guest - 03-15-2010, 01:10 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
