Majestic info
Hi Eric,
I don't think it's a matter of recognizing it looks like you have found whats available for the service info. Unfortunately
it's somewhat incomplete.
Has someone remove or changed out the original caps and resistors?
Majestic info - by Eric - 10-05-2017, 05:16 PM
RE: Majestic info - by Radioroslyn - 10-05-2017, 06:08 PM
RE: Majestic info - by Eric - 10-06-2017, 10:08 AM
RE: Majestic info - by Radioroslyn - 10-06-2017, 01:03 PM
RE: Majestic info - by Eric - 10-07-2017, 09:21 AM
RE: Majestic info - by Radioroslyn - 10-07-2017, 02:42 PM
RE: Majestic info - by Eric - 10-08-2017, 10:02 AM
RE: Majestic info - by Dan Walker - 10-08-2017, 10:52 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
