Crosley 106CP Modulation Hum
I had a look at the schematic for this set, it's a 1946-47 model by the way, and it shows a .01 uf capacitor connected between one leg of the transformer primary and ground, which is the same side that is connected to the power switch. Many non Philco radios, such as RCAs and G.Es, used what is called an electrostatic shield to reduce noise coming in from the power line, it's a strip of copper foil wrapped around the outside of the transformer windings and connected to ground.
http://www.nostalgiaair.org/Resources/191/M0003191.htm
Crosley 106CP Modulation Hum - by Raleigh - 10-02-2017, 01:56 PM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-02-2017, 08:00 PM
RE: Crosley 106CP Modulation Hum - by Radioroslyn - 10-03-2017, 04:24 AM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-03-2017, 05:35 PM
RE: Crosley 106CP Modulation Hum - by Arran - 10-03-2017, 11:07 PM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-04-2017, 12:12 PM
RE: Crosley 106CP Modulation Hum - by Radioroslyn - 10-04-2017, 01:02 PM
RE: Crosley 106CP Modulation Hum - by Mondial - 10-05-2017, 05:52 AM
RE: Crosley 106CP Modulation Hum - by Arran - 10-06-2017, 12:10 AM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-07-2017, 09:08 AM
RE: Crosley 106CP Modulation Hum - by Radioroslyn - 10-07-2017, 02:50 PM
RE: Crosley 106CP Modulation Hum - by Arran - 10-09-2017, 02:26 AM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-11-2017, 04:44 PM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-19-2017, 05:29 PM
RE: Crosley 106CP Modulation Hum - by Ron Ramirez - 10-20-2017, 10:55 AM
RE: Crosley 106CP Modulation Hum - by morzh - 10-20-2017, 11:44 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
