Philco 91-121 sensitivity
Ok so what happens if you have the shield on and the ant off is the signal stronger if you touch the mixer cap or the rf amp cap??
Two other thing come to mind, maybe your 39/44 is flat and what kind of voltage do you have on pin 3 and pin 4.
Typically w/o the ant connected reception should be the loudest when touching the rf amp grid cap. A slight decrease when touching the mixer cap and should go dead (most of the time) when touching the if amp grid cap.
Philco 91-121 sensitivity - by grandntl - 10-05-2017, 03:41 PM
RE: Philco 91-121 sensitivity - by Ron Ramirez - 10-05-2017, 03:58 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-05-2017, 05:34 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-06-2017, 08:51 AM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-06-2017, 10:19 AM
RE: Philco 91-121 sensitivity - by grandntl - 10-06-2017, 12:49 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-06-2017, 01:22 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-06-2017, 02:28 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-06-2017, 03:26 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-06-2017, 05:59 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-06-2017, 07:39 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-27-2017, 03:32 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-28-2017, 08:41 AM
RE: Philco 91-121 sensitivity - by grandntl - 10-29-2017, 12:29 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-29-2017, 01:48 PM
RE: Philco 91-121 sensitivity - by grandntl - 11-01-2017, 10:29 AM
RE: Philco 91-121 sensitivity - by Ron Ramirez - 11-01-2017, 12:48 PM
RE: Philco 91-121 sensitivity - by klondike98 - 11-01-2017, 01:42 PM
RE: Philco 91-121 sensitivity - by grandntl - 11-02-2017, 10:08 AM
RE: Philco 91-121 sensitivity - by grandntl - 11-14-2017, 02:16 PM
RE: Philco 91-121 sensitivity - by klondike98 - 11-14-2017, 02:39 PM
The speaker table error?
Philco 70 antenna lead
