Philco 91-121 sensitivity
With the shield on and antenna disconnected the signal is a lot stronger when touching the 36 cap; the signal is as strong when touching the 44 RF cap as it is when touching the ant connection but a lot weaker than the 36 cap touch. I exchanged the 39/44 RF tube with two spares.... no change in signal strength. The cap replacement looks professional to me but I suppose I should review it ...starting where?
Philco 91-121 sensitivity - by grandntl - 10-05-2017, 03:41 PM
RE: Philco 91-121 sensitivity - by Ron Ramirez - 10-05-2017, 03:58 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-05-2017, 05:34 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-06-2017, 08:51 AM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-06-2017, 10:19 AM
RE: Philco 91-121 sensitivity - by grandntl - 10-06-2017, 12:49 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-06-2017, 01:22 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-06-2017, 02:28 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-06-2017, 03:26 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-06-2017, 05:59 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-06-2017, 07:39 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-27-2017, 03:32 PM
RE: Philco 91-121 sensitivity - by grandntl - 10-28-2017, 08:41 AM
RE: Philco 91-121 sensitivity - by grandntl - 10-29-2017, 12:29 PM
RE: Philco 91-121 sensitivity - by Radioroslyn - 10-29-2017, 01:48 PM
RE: Philco 91-121 sensitivity - by grandntl - 11-01-2017, 10:29 AM
RE: Philco 91-121 sensitivity - by Ron Ramirez - 11-01-2017, 12:48 PM
RE: Philco 91-121 sensitivity - by klondike98 - 11-01-2017, 01:42 PM
RE: Philco 91-121 sensitivity - by grandntl - 11-02-2017, 10:08 AM
RE: Philco 91-121 sensitivity - by grandntl - 11-14-2017, 02:16 PM
RE: Philco 91-121 sensitivity - by klondike98 - 11-14-2017, 02:39 PM
The speaker table error?
Philco 70 antenna lead
