zenith chassis #1oo4
After trying a 25 watt 20 ohm resistor i found that it still ran hot.After talking to a couple of oldtimers in my radio club they said i should actually use a 25w 150 olm resistor to bring down the voltage.Anybody agree.Thanks the boyzz
zenith chassis #1oo4 - by theboyzz - 03-02-2009, 01:15 AM
Re: zenith chassis #1oo4 - by etech - 03-02-2009, 10:24 AM
Re: zenith chassis #1oo4 - by theboyzz - 03-02-2009, 01:26 PM
Re: zenith chassis #1oo4 - by etech - 03-05-2009, 09:06 AM
Re: zenith chassis #1oo4 - by theboyzz - 03-13-2010, 12:11 AM
Re: zenith chassis #1oo4 - by MinnesotaHam - 03-13-2010, 07:04 PM
Re: zenith chassis #1oo4 - by theboyzz - 03-14-2010, 01:39 AM
Re: zenith chassis #1oo4 - by exray - 03-14-2010, 10:23 PM
Re: zenith chassis #1oo4 - by codefox1 - 03-17-2010, 02:03 PM
Eico 232 VTVM Schematic
There are currently 9205 online users. [Complete List]
» 1 Member(s) | 9204 Guest(s)
