Majestic info
Yes their print sucks! Have found sniped wires (6 total) seems to be all around the band switch dealing with SW and the PB's and I suspect the antenna coil is not original but something they had laying around. Big mess but broadcast works.
Majestic info - by Eric - 10-05-2017, 05:16 PM
RE: Majestic info - by Radioroslyn - 10-05-2017, 06:08 PM
RE: Majestic info - by Eric - 10-06-2017, 10:08 AM
RE: Majestic info - by Radioroslyn - 10-06-2017, 01:03 PM
RE: Majestic info - by Eric - 10-07-2017, 09:21 AM
RE: Majestic info - by Radioroslyn - 10-07-2017, 02:42 PM
RE: Majestic info - by Eric - 10-08-2017, 10:02 AM
RE: Majestic info - by Dan Walker - 10-08-2017, 10:52 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
