Crosley 106CP Modulation Hum
Yes;
  If there is an electrostatic shield it is inside of the transformer, sometimes they wrap some of the copper foil on the outside of the iron, but most of the time you would have to remove one of the end bells (covers) to see it. However if the set had one it would be indicated on the schematic as a line parallel to those denoting the iron laminations, but with a ground symbol attached.
Crosley 106CP Modulation Hum - by Raleigh - 10-02-2017, 01:56 PM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-02-2017, 08:00 PM
RE: Crosley 106CP Modulation Hum - by Radioroslyn - 10-03-2017, 04:24 AM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-03-2017, 05:35 PM
RE: Crosley 106CP Modulation Hum - by Arran - 10-03-2017, 11:07 PM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-04-2017, 12:12 PM
RE: Crosley 106CP Modulation Hum - by Radioroslyn - 10-04-2017, 01:02 PM
RE: Crosley 106CP Modulation Hum - by Mondial - 10-05-2017, 05:52 AM
RE: Crosley 106CP Modulation Hum - by Arran - 10-06-2017, 12:10 AM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-07-2017, 09:08 AM
RE: Crosley 106CP Modulation Hum - by Radioroslyn - 10-07-2017, 02:50 PM
RE: Crosley 106CP Modulation Hum - by Arran - 10-09-2017, 02:26 AM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-11-2017, 04:44 PM
RE: Crosley 106CP Modulation Hum - by Raleigh - 10-19-2017, 05:29 PM
RE: Crosley 106CP Modulation Hum - by Ron Ramirez - 10-20-2017, 10:55 AM
RE: Crosley 106CP Modulation Hum - by morzh - 10-20-2017, 11:44 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7134 online users. [Complete List]
» 1 Member(s) | 7133 Guest(s)
