Philco 53-1350 Resistor Overheats
>>Our son is repairing this radio, and he understands the electronics.
Let him come here then and ask questions directly. It's a good thing he's into it all. How old is he?
Philco 53-1350 Resistor Overheats - by Farmer MM - 10-07-2017, 08:09 PM
RE: Philco 53-1350 Resistor Overheats - by morzh - 10-08-2017, 05:28 PM
RE: Philco 53-1350 Resistor Overheats - by morzh - 10-09-2017, 02:11 PM
RE: Philco 53-1350 Resistor Overheats - by David - 10-09-2017, 05:34 PM
RE: Philco 53-1350 Resistor Overheats - by David - 10-09-2017, 05:37 PM
RE: Philco 53-1350 Resistor Overheats - by David - 10-09-2017, 08:53 PM
RE: Philco 53-1350 Resistor Overheats - by morzh - 10-09-2017, 10:16 PM
The speaker table error?
Philco 70 antenna lead
