16 cathedral survived a trip to Ukraine
And is working out of the box.
That radio was purchased 1-1/2 years ago in Kutztown from John "Hagstar" Hagman to be shipped to Peter in Ukraine. Eventually it got shipped.
It'll have to have some things replaced but receives on all bands nevertheless.
16 cathedral survived a trip to Ukraine - by morzh - 10-09-2017, 10:38 PM
There are currently 11414 online users. [Complete List]
» 2 Member(s) | 11412 Guest(s)
