40-216 restoration questions
Any type is OK in this circuit. It is an RC filter with a large C, so you don't care about stuff like noise (or even tolerance).
RE: 40-216 restoration questions - by klondike98 - 10-10-2017, 06:53 PM
RE: 40-216 restoration questions - by Edisla - 10-11-2017, 11:24 AM
RE: 40-216 restoration questions - by Mondial - 10-11-2017, 01:19 PM
RE: 40-216 restoration questions - by Edisla - 10-12-2017, 12:29 AM
RE: 40-216 restoration questions - by Warren - 10-12-2017, 01:11 PM
RE: 40-216 restoration questions - by Edisla - 10-12-2017, 05:48 PM
RE: 40-216 restoration questions - by Edisla - 10-23-2017, 08:19 PM
RE: 40-216 restoration questions - by Ron Ramirez - 10-24-2017, 09:38 PM
RE: 40-216 restoration questions - by Edisla - 10-24-2017, 11:06 PM
RE: 40-216 restoration questions - by Edisla - 10-24-2017, 11:07 PM
RE: 40-216 restoration questions - by Arran - 10-25-2017, 04:15 AM
RE: 40-216 restoration questions - by Edisla - 10-25-2017, 07:56 PM
RE: 40-216 restoration questions - by Edisla - 10-27-2017, 01:07 AM
RE: 40-216 restoration questions - by Edisla - 10-31-2017, 09:20 PM
RE: 40-216 restoration questions - by morzh - 10-31-2017, 10:18 PM
RE: 40-216 restoration questions - by Joeztech - 11-01-2017, 04:14 PM
RE: 40-216 restoration questions - by Joeztech - 11-01-2017, 04:41 PM
RE: 40-216 restoration questions - by morzh - 11-01-2017, 04:48 PM
RE: 40-216 restoration questions - by Edisla - 11-03-2017, 09:38 PM
RE: 40-216 restoration questions - by morzh - 11-03-2017, 09:55 PM
RE: 40-216 restoration questions - by Edisla - 11-03-2017, 09:58 PM
RE: 40-216 restoration questions - by morzh - 11-04-2017, 07:45 PM
RE: 40-216 restoration questions - by Edisla - 11-05-2017, 06:32 PM
RE: 40-216 restoration questions - by Edisla - 11-06-2017, 11:40 PM
RE: 40-216 restoration questions - by Edisla - 11-07-2017, 09:07 PM
RE: 40-216 restoration questions - by Radioroslyn - 11-07-2017, 09:38 PM
RE: 40-216 restoration questions - by Edisla - 11-07-2017, 10:16 PM
RE: 40-216 restoration questions - by Edisla - 11-08-2017, 08:45 PM
RE: 40-216 restoration questions - by Radioroslyn - 11-08-2017, 08:54 PM
RE: 40-216 restoration questions - by Edisla - 11-08-2017, 09:30 PM
RE: 40-216 restoration questions - by Edisla - 11-08-2017, 10:33 PM
RE: 40-216 restoration questions - by Edisla - 11-17-2017, 09:14 PM
RE: 40-216 restoration questions - by Edisla - 11-18-2017, 12:12 PM
RE: 40-216 restoration questions - by morzh - 11-18-2017, 12:38 PM
RE: 40-216 restoration questions - by Edisla - 11-27-2017, 11:58 PM
RE: 40-216 restoration questions - by morzh - 11-28-2017, 12:33 AM
RE: 40-216 restoration questions - by Edisla - 11-28-2017, 12:54 AM
RE: 40-216 restoration questions - by Edisla - 12-21-2017, 04:17 PM
RE: 40-216 restoration questions - by Radioroslyn - 12-21-2017, 04:57 PM
RE: 40-216 restoration questions - by Edisla - 12-21-2017, 05:04 PM
RE: 40-216 restoration questions - by Edisla - 12-21-2017, 05:56 PM
RE: 40-216 restoration questions - by morzh - 12-21-2017, 06:30 PM
RE: 40-216 restoration questions - by Edisla - 01-11-2018, 12:28 PM
RE: 40-216 restoration questions - by Ron Ramirez - 01-11-2018, 12:45 PM
RE: 40-216 restoration questions - by morzh - 01-11-2018, 02:25 PM
RE: 40-216 restoration questions - by Radioroslyn - 01-12-2018, 12:32 AM
RE: 40-216 restoration questions - by Edisla - 01-21-2018, 01:20 AM
RE: 40-216 restoration questions - by Radioroslyn - 01-21-2018, 01:27 AM
RE: 40-216 restoration questions - by Edisla - 01-21-2018, 01:36 AM
RE: 40-216 restoration questions - by Edisla - 01-28-2018, 11:03 PM
RE: 40-216 restoration questions - by Edisla - 03-05-2018, 12:43 AM
RE: 40-216 restoration questions - by gregb - 03-05-2018, 04:47 AM
RE: 40-216 restoration questions - by Edisla - 03-05-2018, 01:51 PM
40-216 band switch feedback - by Edisla - 09-27-2017, 04:46 PM
RE: 40-216 band switch feedback - by Mondial - 09-27-2017, 10:13 PM
RE: 40-216 band switch feedback - by Edisla - 09-28-2017, 12:47 AM
RE: 40-216 band switch feedback - by Mondial - 09-28-2017, 11:05 PM
RE: 40-216 band switch feedback - by Edisla - 09-29-2017, 10:28 AM
RE: 40-216 band switch feedback - by Edisla - 09-29-2017, 08:39 PM
40-216 5w resistor in place of 2w? - by Edisla - 10-08-2017, 07:41 PM
RE: 40-216 5w resistor in place of 2w? - by morzh - 10-08-2017, 07:46 PM
RE: 40-216 5w resistor in place of 2w? - by morzh - 10-10-2017, 09:14 AM
RE: 40-216 5w resistor in place of 2w? - by morzh - 10-10-2017, 11:10 AM
RE: 40-216 5w resistor in place of 2w? - by morzh - 10-10-2017, 01:55 PM
Users browsing this thread: 21 Guest(s)
The speaker table error?
Philco 70 antenna lead
