Kolster K-20 A.F. Transformer
Ok What you are looking for are https://www.tubesandmore.com/products/tr...tage-10-ma  for both. If the transformers are enclosed and have a 1/2" core you can buy just the replacement winding.
Kolster K-20 A.F. Transformer - by dseverson - 10-10-2017, 01:17 PM
RE: Kolster K-20 A.F. Transformer - by dseverson - 10-10-2017, 03:36 PM
RE: Kolster K-20 A.F. Transformer - by dseverson - 10-10-2017, 05:19 PM
RE: Kolster K-20 A.F. Transformer - by Radioroslyn - 10-10-2017, 08:09 PM
RE: Kolster K-20 A.F. Transformer - by Arran - 10-10-2017, 09:13 PM
RE: Kolster K-20 A.F. Transformer - by dseverson - 10-10-2017, 11:42 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
