Philco 38-7CS Restoration
Hi Bernie,
Perhaps this will clear it up for you. Looking from the back side end terminal on the left goes to #24, the center (wiper) to #28, and the other end to chassis gnd.
As for the tone/off/on sw two of the connections are to the ac circuit (one to the power transformer and other to the ac cord). The other connections connect to # 38, 40, and chassis gnd.
In regard to #30 it may have been a costs cutting discontinuation, it wouldn't hurt to add in back in. It decouples the grid bias voltage to the 6K5. Without it the 6K5 maybe prone to oscillate.
Philco 38-7CS Restoration - by beanderson - 10-11-2017, 11:41 PM
RE: Philco 38-7CS Restoration - by beanderson - 10-12-2017, 01:11 AM
RE: Philco 38-7CS Restoration - by Radioroslyn - 10-12-2017, 04:13 AM
RE: Philco 38-7CS Restoration - by beanderson - 10-12-2017, 06:47 AM
RE: Philco 38-7CS Restoration - by beanderson - 10-16-2017, 10:55 PM
RE: Philco 38-7CS Restoration - by Radioroslyn - 10-17-2017, 08:26 AM
RE: Philco 38-7CS Restoration - by beanderson - 10-27-2017, 10:25 PM
RE: Philco 38-7CS Restoration - by Radioroslyn - 10-28-2017, 10:43 AM
The speaker table error?
Philco 70 antenna lead
