41-250 restoration
Yes I think it should play without the pushbutton assy when the switch is in proper positions.
41-250 restoration - by keith49vj3 - 10-12-2017, 08:19 PM
RE: 41-250 restoration - by morzh - 10-12-2017, 08:43 PM
RE: 41-250 restoration - by keith49vj3 - 10-13-2017, 06:49 PM
RE: 41-250 restoration - by Radioroslyn - 10-13-2017, 07:40 PM
RE: 41-250 restoration - by keith49vj3 - 10-14-2017, 01:00 PM
RE: 41-250 restoration - by David - 10-14-2017, 01:28 PM
RE: 41-250 restoration - by Radioroslyn - 10-14-2017, 03:16 PM
RE: 41-250 restoration - by keith49vj3 - 10-14-2017, 04:04 PM
RE: 41-250 restoration - by Radioroslyn - 10-14-2017, 08:45 PM
RE: 41-250 restoration - by keith49vj3 - 10-15-2017, 05:10 PM
RE: 41-250 restoration - by keith49vj3 - 11-03-2017, 09:32 AM
RE: 41-250 restoration - by keith49vj3 - 11-03-2017, 09:34 AM
RE: 41-250 restoration - by morzh - 11-03-2017, 10:09 AM
RE: 41-250 restoration - by klondike98 - 11-03-2017, 12:11 PM
RE: 41-250 restoration - by KCMike - 11-03-2017, 01:08 PM
The speaker table error?
Philco 70 antenna lead
