40-216 How would you handle this?
You can try all sorts of things. It is very likely that none of them will be permanent.
You have 2 layers of broken veneer and poor adhesion. Differences in humidity and temperature are likely to open this radius split again over time.Replacement of the veneers and inspection/repair of the underlying structure are the only long term fix.
40-216 How would you handle this? - by Edisla - 10-12-2017, 12:33 AM
RE: 40-216 How would you handle this? - by Edisla - 10-13-2017, 10:44 PM
RE: 40-216 How would you handle this? - by Phlogiston - 10-14-2017, 12:21 PM
RE: 40-216 How would you handle this? - by Arran - 10-15-2017, 02:27 AM
