Philco 70 non-AVC resistor added to 2nd detector plate to ground
I no longer power up a radio without having checked the tubes prior to it. Granted even that is not a guarantee, but gives you some degree of assurance.
RE: Philco 70 non-AVC resistor added to 2nd detector plate to ground - by morzh - 10-16-2017, 08:16 AM
The speaker table error?
Philco 70 antenna lead
