48-460 .2 Line to Chassis Capacitor Question
Actually this is not a 'wavetrap' in the reception sense of the word. Philco apparently recognized that they were not bypassing IF frequencies to ground very effectively due to the inductance of the old foil wound caps. The solution was to add more inductance in series to 'tune' it to 455 for better bypassing at that frequency. Its all explained on Chuck's site.
Since modern caps don't have the same issue as the big old paper caps the coil is no longer required.
48-460 .2 Line to Chassis Capacitor Question - by Guest - 04-14-2010, 09:25 PM
Re: 48-460 .2 Line to Chassis Capacitor Question - by exray - 04-15-2010, 08:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
